Smart Clean - Super Speed Cleaner Booster
linlinvvann
  • Post del forum: 5
28 lug 2017, 09:24:28 Tramite pagina web
Smart Clean cleaner master app, your power cleaner, junk file cleaner & speed booster to make phone faster and restore memory space.
Smart Clean, as professional Android power cleaner & optimizer, can clean cache junk files to reclaim storage; stop unnecessary apps in background to clean RAM and speed up your Android phone; stop apps from auto-start to save battery life; quickly delete duplicate photo to save more space; boost games to run faster without lagging with all-in-one powerful super cleaner master app.
play.google.com/store/apps/details?id=com.junk.clean.smart.cleaner
Alexander Beckham
  • Post del forum: 41
31 lug 2017, 09:53:49 Tramite pagina web
Solo Launcher
With over 100 million users worldwide, Solo Launcher is one of the Top 3 Launchers in the category on Google Play. With its array of DIY features, the launcher enables you to customize the user interface on a device so it works in the way you want. It takes up only a small amount of space yet it can boost device performance by restoring memory, run smoothly, and more fun to use.
de89e6_1
What Can Solo Launcher Do Better Than Competitors?
- One of the first launchers that use Material Design 2.0.
- Cleans cache to boost speed clears storage and saves memory faster.
- Customize your device by using any of the thousands of beautiful themes, wallpapers, and smart widgets in our collection that are fast and simple to install.
- New Locker plugins make it easier to protect your device from unauthorized users.
- Most featured launcher on Google Play.
de89e6_3
Solo Launcher Highlights★
► Search for Information
Everything you want to know can be found here.
► Clean & Boost
Make your device fast as lightning.
► Quick Gestures
Make it super easy to use your device.
► DIY with Photos
Set your photos as icons, with various effects to choose from.
► Beautiful Themes
Thousands of beautiful themes and wallpapers are available for free.
► Beautiful Wallpaper
Gentle click, and get new wallpapers for a new mood
► Solo Now
Right side, and see the vast of the world.
★Additional Features★
Visualized Settings
- A smart menu for settings that helps you easily change the device in the way you want.
Smart HomeScreen Icon Management
- Automatically places frequently used apps on the home screen, helping to organize the device and making it more convenient to use.
Smart Widgets
- Customizable Clock&Weather widgets, Boost Button widget, Search widget, App Lock, Battery Saver, and more!
☆Beautiful Handwritten Fonts, that are cool &attractive.
☆Optional App Lock & Lock Screens that can help make your device safe and secure.
☆Optional Battery Saver helps manages battery consumption, reducing the frequency you need charge your device.
☆Weather &Clock Widgets offer you accurate weather forecasts.
☆Integrated Solo 2.0 Speed Booster that makes devices run smoother and faster, restore space and capacity, clean caches, at the tap of a button!
— modificato il 31 lug 2017, 09:57:43
