- Post del forum: 13
16 gen 2017, 08:29:43 Tramite pagina web
16 gen 2017 08:29:43 Tramite pagina web
If you forget the screen password or your Samsung Android mobiles is out of order, you will need Dr.Fone for Android to remove the screen lock. It removes the pattern, fingerprints, PIN and password on your Samsung Galaxy phones without data loss.
youtu.be/rXADgwgVk_Y
Work with Samsung mobiles like:
Galaxy Note: Note 3, Note4, Note Edge, Note5;
Galaxy S: S3, S4, S4 Mini, S4 Active, S5 and more.
